RCU Forums - View Single Post - First hobby grade buggy...pulls to the right?
Old 01-03-2012 | 04:26 PM
The_Shark's Avatar
The_Shark
Default RE: First hobby grade buggy...pulls to the right?
... make sure your steering trim is streight when coasting, once that is done if it pulls hard one direction check for sloppy linkage and suspension parts, if thats fine re-allign it so every tire is pointed the same on both axles.
its pretty normal for a car to pull a little under acceleration, unless its a hard pull or constant "darting" its somewhat normal.
ps, read up on toe, camber, caster adjustment.
