RE: KMP OV-10 Bronco (refurb job)
Ok , doesn't look like much was done tonite but what was done took time.
Pic# 1 is the old servo mount. The 8711 was really giving the F/G nose cone the twist. I have moved the servo back behind the gear now. I have looped inner nyrod around to the front and then back again. Pic#2.
Pic #3 is the new formers and stringer in the F/G cone. They are glued in now. This will get a 1/32 plywood skin on it to cover it up. then I can F/G it and blend it in with body filler.
Pic#4 I got the sheeting back on the bottom of the fuse pod. I will sand that tommorow.
That all for tonite,
Kelly
