RCU Forums - View Single Post - Retract and door sequencing?
Old 01-04-2012 | 03:07 AM
madmodelman's Avatar
madmodelman
Default RE: Retract and door sequencing?
You need a sequencer, the gear channel obviously operates the gear via rx input, the sequencer then operates your door valve for you automatically and timed, therefore all done only using one channel.
I like the Jet-tronic one best.
You could use two channels but you would have to operate them manually and that's too much to think about when you are flying.
