ORIGINAL: Enrique-F3A
It is undeniable that the electrics have many advantages such as virtually no engine maintenance, less vibration, hence longer servos life, more motor and models options, and others. However, regarding flight time, the IC has a huge advantage. As it has been told here, you can fly up to 18 minutes (glow). Four flights of 18 minutes each gives 72 minutes total, that is equivalent to about ten flights with the electric; it means more batteries, more takeoffs and landings, that is not useful time to practice the maneuvers that really matter. It also appears that the YS develops more torque than any available electric motor today, this, specially in windy days is an advantage that can not be ignored by serious pattern fliers. In spite of it is also undeniable that the trend is electrics, in my particular opinion, glow or electrics, is a difficult decision to take at this time !
Regards
Enrique
I agree with all of the above except the torque statement. Electrics deliver instantaneous torque, whereas even the best of the YS stuff does take a second to spool up. That is one significant advantage for electrics. A few years ago there was an advantage with glow in the wind, but it wasn't the torque, it was the ability to use the available power while still having power at the end. As the batteries, motors, and ESC's have improved this is no longer the case. I flew YS for years and loved my YS stuff, but I have yet to fly a YS, 1.75 included that had the instantaneous torque of my Neu setup in my Wind S Pro. It is impossible for an internal combustion engine to produce the instantaneous torque than an electric motor can produce. The YS stuff certainly has more than enough torque, but if you do a vertical snap at less than full power to where the plane virtually stops and then add the power back, you will see what I mean. The YS will easily climb out whereas the electric almost looks like it is shot out of a cannon. Now, I'm comparing the best electric setups, not your lower end outrunner.
Arch
