RE: Nitroplanes Skymaster 337, Build Tips
<font face="Helvetica, Arial, sans-serif">Hi Wayne,
I really like this plane. However I am not very happy with Nitroplanes support. They have not made this plane for some time now and have not given me any support from the day I purchased.
When I received the plane the canopy was damaged. I did contact them about the damage and they gave me the runaround and never sent a replacement.</font><font face="Helvetica, Arial, sans-serif"> So I fixed it with no major problem.
I installed 2 Magnum .91 4 strokes and really like the power. I also installed the TwinSync system, however this plane doesn't need it since the engines are in-line. I just like the sound of perfectly synced engines.
I installed 2 x 26oz. fuel tanks and get as much as 35 minutes of flight.
With all the additions my plane weight is around 16 pounds! That's why I jokingly called it a pig.
I use 3 1/2 inch tires and reinforced the landing gear to accommodate my weak landing skills.
If you follow my build modifications this plane is easy and quick to setup at the field.
Flight is very steady. It likes to land long - use flaps for landing.
I haven't had much problem with the lack of rudder, however a strong crosswind will push her off course or tip her over.</font>
