RE: Electronics question - can't find replacement mosfets
I tested the resistors and diodes. I'm not sure if the resistance on the resistors means a thing since they were tested still attached to the board but I'm guessing they are fine. Plus they all read the same resistance anyways.
There is one diode on the board, it reads the same both ways, resistance in the megaohms. Even when attached to the board I don't believe this should occur. With positive touching the silver ring end, there should be zero connection. I've been working like mad but I should get around to changing it out within the next couple of days and I'll post what happens. Thanks everybody for the help and suggestions.
**update
I pulled the diode out, it reads normal when off the board so I soldered it back in. Bummer on that, back to ground zero...
