ORIGINAL: DougC1
The fiber-glassing is progressing, but slowly. Yup, resin is interesting stuff…….allow me to ramble for a bit.
After three coats of resin to the wing on top of the applied fiberglass, I’m finding that there are still too many unsatisfactorily filled areas (the resin is very willing to tear/shear when using a squeegee, and when wiped on when first mixed, will actually orange-peel a bit as it thickens). I’m confident that I sanded sufficiently prior to applying the glass, and know that I’m sanding sufficiently to remove all excess resin, as I’ve not added a single gram in weight since applying the first coat of unthinned resin (bare wing at 669 grams, ‘glassed wing, followed by one coat of resin, sanded, weighs 791 grams (4.3oz added)). That is to say that the last two coats of resin have added no weight, as the wing still weighs 791 grams.
I’m going to try filling just the remaining low spots, a quick sand to ensure that they are at least to level or above, another complete coat, then (hopefully) a final sand.
I’m finding that the resin consistently gets thicker from the moment that it’s mixed (doesn’t suddenly “kick” like a quality epoxy will), and I have to modify my method of application while coating a larger area. I’m glad that I ‘glassed the wing first, as straighten out my learning curve on the fuselage would have been more painful.
Doug
Doug,
Sorry, I stopped reading after I read "3 coats" of resin. I see that you are taking weights. Good!
The wing should be ready to prime. What I mentioned earlier about Klass Kote primer stands. I admix equal volumes of part A, part B, Johnson's baby powder, and thinner. Let it stand for 10 minutes, remix it and spray it. Cures well enough to wet sand in about 4 hours at 70 degrees (full cure takes longer as all two part paints do). Save the extra paint for touch up where the weave shows through. If you can make the RTF wing come in at less than 2 pounds it will be better. Consider that many will typically build 475 sq inch panels finished but before equipment, weighing in at 12 ozs
