RCU Forums - View Single Post - First time builder.... questions
Old 08-27-2003 | 01:23 AM
jalusa
Default Now the servos
I am preparing to install the servos. A couple questions...
It appears that the servos float sandwiched between two rubber pads that the screws pass through. The directions from Futaba state that they should not touch the model anyplace else. Do I really need to make sure the openings are large enough so that the servo does not touch wood?
I assume I drill small holes and then just screw into them. Is that it? The servo trays don't seem substantial enough to just thread a wood screw into and have it hold. Do you use any other kind of dope on the screw to keep it in place?
Thanks again for the help.
Jim
