RCU Forums - View Single Post - First time builder.... questions
Old 08-27-2003 | 02:50 AM
JohnBuckner's Avatar
JohnBuckner
Default Re: Now the servos
Originally posted by jalusa
It appears that the servos float sandwiched between two rubber pads that the screws pass through. The directions from Futaba state that they should not touch the model anyplace else. Do I really need to make sure the openings are large enough so that the servo does not touch wood?
Thanks again for the help.
Jim
Jim yes the servo should not touch a servo tray any where. If it does that will stop the rubbers grommits from suppying the vibration isolation they were intended to do. Those grommits also come with a brass bushing with a shoulder on it. These bushings are inserted upside down from the bottom up. In this way when the screw is inserted from the top through the grommit and bushing and tightened it will not crush the grommit allowing the grommit to do its job.
John
By the way what radio system are you using and what model servo. The appropriate servos for that airplane all have four screws mounting each servo and not two?
