RCU Forums - View Single Post - Tricks and Tips to keep your Redcats running!
Old 01-05-2012 | 09:52 PM
nitrosportsandrunner's Avatar
Default RE: Tricks and Tips to keep your Redcats running!
Zip ties can be very useful when bashing.
Ever lose a screw that holds you shock to the a-arm or shock tower? I have, and used a small ziptie to hold the shock in place! Just put the zip tie thres the shock's hole and the hole on the tower or a-arm. Doesnt look pretty, but kept me running for the day.
Ever remove a tire...and have the hex's drive pin fall out and get lost[:@]
Most body clips can be cut using a pair of wire cutters...down to the right lenght to be used as a drive pin.
