RCU Forums - View Single Post - 72 antenna question
Old 01-06-2012 | 04:09 AM
exeter_acres's Avatar
exeter_acres
Default RE: 72 antenna question
ORIGINAL: markhamregular
<div style=''margin: 0in 0in 10pt''>I am building a F20 Tigershark with a 72 radio. Is it OK to run the antenna on one side inside the fuse, turn it on the tail and run it back on the other side?</div><div style=''margin: 0in 0in 10pt''>Thanks,</div>
as you are running the antenna down one side and back the other and not Overlapping.....
yes, this should work fine.
as always perform a good range check
