ORIGINAL: leadmech
I just bought a midwest aerostar 20 on ebay, I recieved the prints with the kit but the assembly manual is missing, I was able to get a copy of the manuel for the aerostar 40 from midwest, does any one know where I can get the manual for the 20? Thanks
leadmech,
The .40 and .20 Aero-Stars are virtually identical (except for wood dimensions) so if you are unable to get a manual, you should be able to build the .20 no problem with the .40 manual. In building most kits, the plans are what you go with when you find a discrepancy between manual and plans. I wouldn't let the .40 manual stop you from the build, in fact once you get going I think you will find building the Aero-Star .20 a simple build. If you run into any snags, post them here. Good Luck.
