RCU Forums - View Single Post - Spectrum 10
Thread: Spectrum 10
Old 01-07-2012 | 03:59 PM
desertrider49's Avatar
desertrider49
Default RE: Spectrum 10
ORIGINAL: Ryan Smith
It probably has something to do with the fact that the radios are capable of doing Mode 1 and Mode 2 in the same radio. I'm not sure. Do you remember who you talked to?
When you said the RPM changed, I presume that you meant that when you gave a little pressure against the stop, the throttle lowered?
I didn't see his name, I don't want anyone to get in trouble.
Yes, the idle goes down with pressure. I adjusted the throttle to not stall with the pressure, but the idle is too high for normal flying as in stall turns and spins.
