ORIGINAL: JRockZ
ORIGINAL: SyCo_VeNoM
how bad did you bend that chassis plate?
The chassis plate doesnt seem to be bent at all, so far ive been able to replace everything and all fits back together perfect,, I set it down on a counter and inspected from all angles and i see no visable chassis bending, It hit high because the dumpster curves at the bottom so the upper parts took the brunt of the damage, still working on, new way to mount the battery, i shouldve just bought the conversion kit but oh well i didnt lol
pure ofna man! they are TANKS, im sure you could win races simply by smashing into everyone!
your actually better off with twisted shafts, would rather have the shafts warp to nothing than rebuild all the diffs
all the time having the 9.5 ive broken a drive shaft, ball cup and bent a shock tower, why? running through the field as the right suspension arm found a water valve. and ive made this thing tumble-weed land upside down ect.
