RCU Forums - View Single Post - Contemplating. May get back into it....
Old 01-08-2012 | 01:16 AM
thedudeswazhere
Default RE: Contemplating. May get back into it....
ORIGINAL: icedude1989
steer well away from the traxxas gymkhana. from what i have heard over here and on hyperdrift, the run crap offroad and they run worse onroad. and they were getting set up and tuned by some of the best tuners and drifters out there and all come back with the same answer, its not even worth considering as a toy grade because it doesnt do anything of what it is supposed to be doing. if u want look up the posts.
i know this post is old but i would like to argue with this statement it can drift i have had long controled drifts with this car but if your going full throttle and turn its going to spin out of control because its front end is way to light to keep grip and that means the back wheels are getting all the power if you are light on the throttle then its actually drifts pretty well while most drift cars you stay full throttle untill you want to straighten it out and the fiesta gymkhana K.B. edition was not ment for off road unless you bought the bfgoodwrench rally tires even then its only ment for smooth dirt roads and you can also change it from a 4WD to a RWD or FWD by taking out a few screws and removing one of the drive pins
