RCU Forums - View Single Post - Top Flite Staggerwing
Old 01-08-2012 | 03:16 AM
  #1716
GaGeeBees's Avatar
GaGeeBees
My Feedback: (23)
Default RE: Top Flite Staggerwing
ORIGINAL: njmheli
Hi To All.
I have been away from this ''thread'' for sometime,great to see it is alive and well !!!
I have been away from mt S/W project,details of which I posted some time ago............I have now finished her and just awaitng to do the maiden ( at long last !!! ).
I have run in my Saito 200R3,pleased to report that there appears to be plenty of power + it sounds great !!! I found out that the idle mixture was too rich,it was giving me a bit of trouble with causing a plug to ''go-out'' at extened lowish RPM's......I have now in addition to the ''mixture'' fix added an ''on-board'' glow system............working great.
I know that this subject has been talked about alot.........CORRECT POSITION FOR C of G !!! ........I would just like to confirm with you all that the position I have is correct by the ''flying-results'' you have all acheived.I have set mine to 5 1/2'' from the leading edge of the lower wing.At this point she balances with a slight ''nose'' down attitude ( Wheels are retracted ).If I get it right,I have posted a photo of the position of the c of g.I will set about 30% expo and will increase the upper limits of the control throws to start with.
Thanks to all for the thread.
Cheers.............Nick (UK).
Looks "good"
