ORIGINAL: king_arthur1953
Very clean Zippi. Did you make an access hatch to access the EI and battery. I hated pulling everything out to get to it. Not mention the fire when the ignition battery blew. That was a mess.
I have some foam pushed in under the tank so if something was to happen I can pull it out pretty quick. If the wing is off. I the wing is bolted on there wont be much I can do. I'm banking on passed history. I have never had a fire...yet.
