RE: need help for my rio 51
A little through the tube at rest is typical. Sometimes you will get water, others not. Disconnect the water tube hose at the pickup. Blow into it as you place your finger on the water outlet hole at the side of the hull. If it's tight, the cooling system should be at least mostly sealed. Is the water coming in as you "tub" test or actual running in a pond?
