RCU Forums - View Single Post - 72 antenna question
Old 01-09-2012 | 03:26 PM
Oberst
Banned
Default RE: 72 antenna question
ORIGINAL: markhamregular
Peter,
Why is it important that only 1 or 2 inches hang outside?
If the 90% os the antenna is inside and work, what exactly make that small portion play an important role?
From what I understand it's good to have a little peeking out of the fuselage. The reason? It is so you will have a better chance of getting the full range, and less chance of a glitch or interference from your own electronics, pushrods and etc.
I have not ever completely hidden a 72mHz antenna in a fuselage, and for me to say to do so is not copasetic. Different radios have different signal strengths, so to be safe I suggest that you have at least 1-2" sticking out of the fuselage or get a whip antenna to be safe.
If you don't believe me read this:
http://www.rc-cam.com/ant_exp.htm
It talks about the different antenna experiments and explains the basics on how your RX works. You can come to your own conclusion about it like I'm sure you will, I only gave you my experience in what I do to hide the antenna without loosing range. If you were to look at my planes sitting on the ground, you would think I was running 2.4GHz until you saw my transmitter.
I have a inch exposed, but you wouldn't see it on the ground or in flight- you would only see it if I flipped the plane over, and pointed it out to you like I did when I took the pictures.
Having a inch or so sticking out helps to get a better signal in my opinion, less junk the signal has to go through. I don't know if that's true or not, but that's what I believe, and to me it makes sense. Hope it does for you?
Pete
