RCU Forums - View Single Post - adding weight?
Old 01-10-2012 | 07:40 AM
skyhawkjock
Default RE: adding weight?
Adding any weight anywhere on the airplane increases the wing loading and stall speed. Always think removing weight first, i.e. nose heavy, remove what weight you can from the tail, second move existing equipment/components to achieve better balance, third and last resort add weight ( if you have already done One and Two above, it will be much less than just adding weight alone.
