RE: KMP OV-10 Bronco (refurb job)
Ok, here are the pics of the gear doors for the nose gear. It's working very good but I still need to do a little tweeking.
pic#1 is 2 1/32 ply and 1 1/64 ply. the notches are in the middle 1/32 piece. (Press glued together.)
I haven't put the rear cover in place yet. It and the left (bottomside) rear hinge had to be made removable to remove the gear as it is offset to one side.
Some parts are taped on for fitting.
Also moved and made a new mount for the air tank and started setting the wing back up. The previous owner used Z bends on the control arms. I'm not real crazy about this but, they are tight and I can't see how they could fail. I may keep this setup.
Kelly
