RCU Forums - View Single Post - adding weight?
Old 01-11-2012 | 07:25 AM
  #43
cutaway
Default RE: adding weight?
I think I'd have just bolted a bunch of weight at the C/G after having put so much time into building it if I thought too light was the problem.
I've found that putting existing designs on radical diet plans can cause unwanted structural flexing unless the whole structure is reconsidered. This is particularly true when plastic coverings are used on open frame construction. What might feel fairly stiff on the ground doesn't stay that way with flight loads.
