RCU Forums - View Single Post - Silk
Thread: Silk
Old 01-11-2012 | 01:48 PM
Azcat59
Default RE: Silk
I use nitrate dope to adhere the silk and for the doping to fill the weave. Make sure you do not get the Non-Tautening type for this however. And be aware that you need to dope the framework, every piece of wood that the silk will touch, and sand lightly, several times BEFORE you put the silk on. Then you lay the silk on the wing (for instance) and leave an inch or two all around the edge. Spray the silk until it is wet, which will make it stick to the wood (like a wet T shirt). Pull out, but don't stretch, any wrinkles. Then dope around the perimeter with thinned dope, rubbing it in as you dope, about 6 inches at a time. Let it dry, and then use an old-fashioned double edge razor blade to trim the excess around the edges.....it works better than a single edge, and you cannot just sand off the excess as you would with fiberglass. Now, when you dope the tightened silk, dope first around the edges but do NOT dope the entire swath that you doped to adhere the silk, or you will allow the tight silk to pull itself back from the edge, and you will have a large wrinkle......just dope half of the swath at a time. then when it is dry (10 minutes or so) go back and dope the other half. Now you are ready to dope the center of the wing. Using dope that is thinned down by at least one-third, dope with what we used to call "a dry brush", i.e. swipe the brush across the rim of the dope bottle or can, then make a very fast brush across the silk. You will not be able to fill the grain all on the first coat....if you try to put the dope on too heavy it will soak through and puddle on the inside, leaving a blemish that you will never get rid of. After a couple of coats using this technique you should pretty well see that there are few if any pin holes left, and then you can lay the dope on heavily. This is all much easier than it sounds when typed out. Now, since nitrate is not fuel proof, if you are using glow power, you will need to paint over the nitrate with butyrate, Klass-Kote epoxy paint, Rustoleum, or other spray paint that is fuel proof.
You may accomplish all of the above using butyrate dope all the way through if you wish, but if you do, you must use butyrate for the final color coats, and not the other paints listed above.
Sorry for the long "tutorial" but I guess somebody should both encourage you, but warn you of the pitfalls that can exist. A silk finish is a thing of beauty, and it will never loosen up with weather changes, etc.
Oh....one thing I forgot....the silk has a "grain" to it, and you must put it on with the grain running spanwise, not chordwise. You can tell which direction by the folded over and ironed edge that you should see on each side of your piece of silk out of the package...that edge should run spanwise, or lengthwise on a fuselage.
Clair Sieverling
