RE: Flash Unit in Hobby Engine M1A2
The groove worked. When you cut into the barrel there is a spring in the front section of the barrel. I cut the spring apart and pulled the pieces out. I then cut the groove all the way back. It looks like there is a tube in the barrel where the spring for the recoil is. I was able to stuff the wire into the barrel. Now for the putty work LOL.
