RCU Forums - View Single Post - Seagull Super Tucano
Old 01-13-2012 | 12:36 AM
rk212
Default RE: Seagull Super Tucano
ORIGINAL: nefariousrc
Great build but that 15x8 prop is to small.. Even a 15x10 unloads enough in the air to put you over 9k. If you absolutely must run a 15" prop then you should go to a 3 blade to load the DLE 20 more.
Hi nefariousrc, welcome to the thread!Do you have any data on the DLE20 with 15x8 or 15x10 props please?Did you have an experience with this?DLE themselves have said a 15x8 would work. I can't imagine they would recommend if it could over-rev or blow DLE
