RE: Runtime calculator
Also, consider the amount of current you will be pulling. Since this is a high speed project, chances are you are geared quite high and tall gearing will pull more current. Those ~3000mAh cells better have one heck of a high true C rating to be able to deliver the high currents. As current=mAh*Crate, the lower in mAh you go, the higher the C rate needs to be.
