<![if gte mso 9]><xml><w:WordDocument><w:View>Normal</w:View><w:Zoom>0</w:Zoom><w:PunctuationKerning /><w:ValidateAgainstSchemas /><w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid><w:IgnoreMixedContent>false</w:IgnoreMixedContent><w:AlwaysShowPlaceholderText> false</w:AlwaysShowPlaceholderText><w:Compatibility><w:Br eakWrappedTables /><w:SnapToGridInCell /><w:WrapTextWithPunct /><w:UseAsianBreakRules /><w
ontGrowAutofit /></w:Compatibility><w:BrowserLevel>MicrosoftInternetE xplorer4</w:BrowserLevel></w:WordDocument></xml><![endif]><![if gte mso 9]><xml><w:LatentStyles DefLockedState="false" LatentStyleCount="156"></w:LatentStyles></xml><![endif]><![if gte mso 10]><style> Style Definitions */table.MsoNormalTable{mso-style-name:"Table Normal";mso-tstyle-rowband-size:0;mso-tstyle-colband-size:0;mso-style-noshow:yes;mso-style-parent:"";mso-padding-alt:0in 5.4pt 0in 5.4pt;mso-para-margin:0in;mso-para-margin-bottom:.0001pt;mso-pagination:widow-orphan;font-size:10.0pt;font-family:"Times New Roman";mso-ansi-language:#0400;mso-fareast-language:#0400;mso-bidi-language:#0400;}</style><![endif]><p class="MsoNormal"><span style="font-size:10.0pt;font-family:Arial">I didn’t reinstall the eyelets. <span style="mso-spacerun:yes"></span>I simply put some heavy plastic tape on the outside of the each hole and then filled the hole with regular epoxy. I also added some glass chop in the center of the enlarged hole and then laid 3 layers of glass on the top of each repair. </span></p><p class="MsoNormal"><span style="font-size:10.0pt;font-family:Arial"></span></p><p class="MsoNormal"><span style="font-size:10.0pt;font-family:Arial">As it relates to the o-rings – I gave up on those. I’m using rubber back #6 washers (#4 would work too).<span style="mso-spacerun:yes"> </span>They aren’t as noticeable as you might think. </span></p><p class="MsoNormal"><span style="font-size:10.0pt;font-family:Arial"></span></p><p class="MsoNormal"><span style="font-size:10.0pt;font-family:Arial"><span style="mso-spacerun:yes"></span><span style="mso-spacerun:yes"></span></span></p>
