ORIGINAL: Aussie_Knife_Edge
ORIGINAL: shannah
Thanks Chris,
Since my brand new Neu motor failed, I also had to confiscate that from my standard Visa for a while. You wouldn't happen to have a spare one of those lying around would you???
Looking forward to flying this weekend. Lots of practicing to do.
Hi Steve,
What happened to the new Neu?
Cheers,
Jason.
Hi Jason,
I'm not sure exactly what happened to it. It was in my Contra Drive setup on my Visa. Brenner thinks a motor winding shorted out and then caused a failure in the drive due to overheating. The bearings were totally seized up on the drive. I originally thought it was the drive that seized up and then burned up the motor. But, since one winding was shorted out and blackened and the others were fine I think Brenner is right. I sent it back to see what Steve Neu says.
I have had great luck with my Neu motors for the past 18 months. Both of my motors were running great. Absolutely no problems at all. This is my first failure in a long time. Prior to the last 18 month run of no problems, I had to send them back for fan and wire problems. Once they squared that away I've been happy.
Steve
