RCU Forums - View Single Post - How to replace a crankshaft bearing?
Old 01-13-2012 | 10:56 PM
mach2's Avatar
mach2
Default RE: How to replace a crankshaft bearing?
Its a thunder tiger MKII trainer that was purchased about 5-6 years ago and has been in the box up until about 2 months ago.
there is no play side to side and it sounds good and runs well. Its only got a gallon and a half through it, and I've made sure my props are properly balanced.
Campgems - I forgot that it's a bushing motor. Thanks for the reminder. I suppose it is what it is, as you pointed out. If it gets super bad ill just get a new crankcase and a gasket set.
Do you think it would help reduce the blow-by if I used a thrust washer that is .001"-.002" thicker?
Jeremy
