RE: Quickie Airfoil Templates
These are experimental wings created by Gary James. They are versions of the S8064 wing used on the Viper and the MH17 used on Bob Harris Hole Shot and Quick shot that have been turned into symmetrical versions of those airfoils.
I have not flown them. I'm not even sure if Gary did. But I saw polar plots of them and they looked good. These are only the templates, and not the numbers. If you want the numbers, you'll have to ask Gary.
I did give away one sheeted wing that was VERY interesting and I heard that it was fantastic. It was the MH17BH.PDF at the root with the MH17SYM_WashoutOneHalf.PDF at the tip. It had lift at the root and was symmetrical with washout at the tips. It was used on a Hole Shot for 424. No fuselage mods were needed.
[link]http://www.rcpro.org/net/ThreadView.aspx?threadid=1013&s=0#msg4[/link]
I may start cutting foam cores to sell again. It was one of the things I did enjoy doing. Even specialty things like the two piece symmetrical to lifting tips with washout cores. If I do, they will be priced higher though. Is $20 reasonable for a nice one piece Quickie 500 wing core?
{edited to add the fact that the hybrid wing given away was sheeted and was a standard MH17 at the root with the symmetrical version at the tip)
