ORIGINAL: saxpg
Sebastian,
I think that it is great that you want to correct original plans, because they make the model too tail heavy.
I agree with you that when you move upper wing behind, you will also get a look that is more similar to Beast.
Maybe you needed to make motor mount longer, but you can do it with spacers also.
One more thing, why there are no holes in the fuse? Model would be much more lighter.
hi saxpg.. my model weight will be 3.5kg maybe 4 kg,you ask whyno have holes in the fuse.. is foam, no need more light there, foam is alrady light. u can see the waight to the fuse.. 307 grams now, now, my friend make the cabanas and landing structure for me, in aluminium aeronautic. i thing in 26CC gas motor, but i dunno.. the plane will be really light. maybe i put an electric motor, for now, i wil build it and later i will see what motor choise.
thanks you.
this is the build post.
http://www.rcgroups.com/forums/showthread.php?t=1568393
