RE: 12fg again
You can, but there are more efficient ways to do it. One of the problems doing it that way is the built in mixes don't like to work that way (such as elevator-rudder and others) With the newer radios Futaba designed the radios to do most of the setup work for you. That is why it asks you how the plane is setup and than you go under the Function menu you and plug things in as it tells you. How John suggested works great as well, but the initial setup is key on the Futaba radios. They are very easy to use once you learn the thought process.
Arch
