RCU Forums - View Single Post - Banshee
Thread: Banshee
Old 01-15-2012 | 09:06 AM
  #73
doxilia's Avatar
doxilia
Default RE: Banshee
Matt,
With the KK clear, do you spray a tack coat on to the wood, lay the cloth down and then reshoot it with a heavier layer of CC prior to primer? Or do you even use primer under the paint?
The concerns I've heard about epoxy based clears as top coats is that they are not impervious to UV - reason for which many classics finished with K&B or Hobbypoxy yellowed as the aged. Any thoughts on that?
David
