RE: Saito FA 45 Prop Driver Removal - Help
The buzz is a problem within the servo electronics itself. The dead band at the zero point of the servo is set too close and the servo is trying to go both directions at once.
The neutral pont needs to be programmed out a bit with a servo programmer?
