RE: GAS OUTBOARD guys this is our new home
Most the flex be sqver in bout ends?
Wuldent it be ok to ounly haw sqver in the end that coms to the engine?
How mutsh "pley" are there in the shaft?
5-6mm ?
Wildent it be bether to haw the flex to be round from the prop shaft and only hawe the sqver end in motor end?
Then there wuldent be the step from sqver to round in the area were it a sharp bend..
I think "this sqver to round area + the sharp bend" is the problem for the flex..
I hawe 3 diferent 1/4" flex home and all of them is "hard" in the area they go from sqver to round..
Do i focus on the right spot here??
is this the area flex broke most of the times?
dothe shaft go short or do it grove in lengt ven drive?
