ORIGINAL: Steve Percifield
The beep after beep you hear is the same thing that happens when you pl;ug the esc into the incorrect receiver channel. It is not receiving the correct signal to operater. I have no idea how to help you with what you are doing.
could be, but not always.. there are some setups.. that even if everything is correct...
when you plug it in.. it will beep.... until you apply throttle...
it is this way to remind the user that it is armed and ready to go.....
