pull-pull control systems
I'm installing pull-pull cables on elev. and rudder to hide the control horns. My question is, does the bellcrank that I hook the cables to from the control surface have to be the same distance apart(attachment points) as the horns on the control surface? This is my first attempt at a pull-pull system,andthe feed back would be appreciated. Thank you.
