RCU Forums - View Single Post - In flight re-pressurizer
Old 01-16-2012 | 03:50 PM
essyou35
Default In flight re-pressurizer
I've seen the fail safes that will put the gear down if pressure is lost. Has anyone seen a device that can repressurize the gears and brakes if pressure goes too low in flight?
I could envision it using a regulated co2 cartridge to get the gears down and activate the brakes. Basically if the gear and/or brakes lose pressure, when the device gets the RC signal from the channel it then knows it ineeds to supplement pressure and kicks in a c02 cartridge to get the gear down and then does the brakes the same way on command. It then could then "reseal" the c02 liek a bb guns does, knowing pressure is lost over time but it would be nice peace of mind.
Thanks!
</p>
