RCU Forums - View Single Post - Aero Works P-51?
Old 01-16-2012 | 05:43 PM
  #934
Zeeb's Avatar
Zeeb
My Feedback: (41)
Default RE: Aero Works P-51?
CG range????
Hey Guys,
This is the first model I've assembled where the manufacturer gives you an exact location for the CG rather than a range. I normally start with a CG slightly ahead of the center of that range for a slightly nose heavy model to do the Maiden flights and initial trimming, and then adjust the CG back to fit my tastes.
So are you guys using the manual's 2 3/4" back from the leading edge at the wing tip only, or is there a range one might use?
I haven't actually checked mine yet as I have to get a friend to come over and help, I'm just trying to cover my bases....
Thanks!
Zeeb is offline
