RCU Forums - View Single Post - In flight re-pressurizer
Old 01-16-2012 | 07:28 PM
KC36330
Default RE: In flight re-pressurizer
bypass air off the turbine is HOT and low pressure, if used as a backup (you have a leak) then the leak will be enough to allow the bypass air to flow at a high enough rate to melt the fittings on the turbine, not a good idea.
