RE: Saito FA 45 Prop Driver Removal - Help
I use a battery terminal puller and heat.I've never had the puller itself remove the alum. drive washer,but pressure from the puller,and then applying heat from a heat gun or a propane torch ususlly pops it off in about a minute.
