RCU Forums - View Single Post - Minimum nitro contents
Old 04-18-2002 | 12:30 PM
Dave Shadel
Default Minimum nitro contents
Greetings from USA!
In warm weather, you might be able to use 15% nitro, but YS engines are designed to use and like higher nitro fuels. Too bad nitro is so expensive over there. It also helps to lower the prop size if you want to runs less nitro and use glow plug heat.
See You,
Dave
