A little forward of half way between recommended and Andrews CG. I think that makes it about 270mm. I tried it back at the recommended also and it didn't need any down elevator when inverted which felt weird to me. I also tried Andrews which I felt needed more throw in horizontal stuff obviously. I fly with small amounts of throw in normal flight but I am trying to learn to fly with a little more throw and use less stick. So I may still move it that extra 5mm forward yet. Not sure as right now, I don't have any trim issue's that I have seen. 2 percent down to low throttle for downlines. I have this on a switch so I can turn it off as it affects 45 down lines and some other things (like any other plane with this mix). It's early on, I have 24 flights on it. Going to get 6 more in here in a few minutes..
C
