RCU Forums - View Single Post - I Dont Have IT
Old 01-18-2012 | 01:52 PM
jimmyjames213's Avatar
jimmyjames213
Default RE: I Dont Have IT
what size prop/engine were you useing? if you were useing a 60 i would recommend a 13x4, if a .75 a 14x4 and a .90 a 15x4. the key for trainers is slow flight, gives you plenty of time to react. i am guessing you had aa 12x6 or something similar which causes the plane to haul....not good when starting out. drop your prop size and keep the throttle low....should be much closer to realflight
