installing Gas engine stuff in plane
In my Deweyville I mounted the DLE20, fits nice, just too big for the cowl, which I could probably make one that does. Anyhow Iam trying to figure out how to connect the throttle up, and if Ineed to hook up the choke. Ialso am trying to determine where to mount the ignition box. Is it possible to take the metal cover off the cable so I can pass it through the firewall? What should I use to connect the servos? and how would I set up a choke servo?
Would there be any issues having the box in the same compartment as the gas tank? Ithink I can mount it to the back of the firewall with either double stick foam tape, or velcro.
The manual it came with sucks, but the one online from THseems pretty good, I just didnt have access to it at the shop where Iam putting it together.
