RE: Composite ARF Tucano Build
Hi guys,
I'm the guy Beave is refering to - that reminds me that I need to get the static RPM for you, Beave. Have patience, i'll get them when spring arrives.
I have about 25 flights on the Tucano with JC V3.
I'm running with 170.000 RPM and 8500 prop RPM. I'm running a 24/12 prop but will change it to a 24/14. The 24/12 is a little too noisy.
The Biela props for turboprops are rated to 10.000 RPM, Beave so that shouldn't be any problem.
Martin
