RCU Forums - View Single Post - Glow Engine for 0% nitro?
Old 01-19-2012 | 03:47 AM
Lifer's Avatar
Lifer
Default RE: Glow Engine for 0% nitro?
MVVS engines run fine on no-nitro. Most European engines are set up that way. Other engines can be run that way by changing head gaskets to increase compression and using higher heat-range plugs. Given the cost of nitro, your choice of running this type of fuel is a good decision.
