RCU Forums - View Single Post - Silver Swallow Pulldown
Old 01-19-2012 | 03:11 PM
  #73
Recycled Flyer
Default RE: Silver Swallow Pulldown
ORIGINAL: 123Cat
I started to mod the No2 Silver Swallow today and thought I would start with a 32 mm long conrod first , the stock rod is 21 mm long
Im going to build the rest of the engine around this rod , it should be done on Monday
Picture of the No1 Silver Swallow
Chinese Power
You are going to build a new engine with a rod modified to half as long again?
I am sure that it is possible but tell me how you are going to get the primary compression ratio back to anything near 1.6:1?
You are bound to increase the volume below piston by a relatively huge amount by raising the piston crown's hieght.
And how would you space the liner up by 11mm, that is a massive amount for such a small engine!
