ORIGINAL: rcjetsaok
I was told there is a Pipe/Tailsection over temp problem with the Skymaster 1/6 F-16 with the P200/Mammoth/Olympus size engines... Max recommended is the P160/Rhino/Pegusus class engines... 36/38 lbs.... You might check with Skymaster on that... I know for a fact that is the case with the F-86...
Danno
Built 2 of the large SM F-86's...one P-200 powered and one powered by the AMT Oly....also had the large SM F-16 with a P-200....no overheating issues whatsoever...all 3 had Tam pipes. Hundreds of flights between the 3.
