RE: Official E-FIRESTORM thread
Hey Xx one way to check to see if that is the issue, is unplug your steering servo from the receiver and plug your ESC into the steering port on the receiver. Then see if the steering knob on the transmitter will work the throttle. If that works, then you know the ESC is good and the problem is in the receiver. if it doesnt work, then it is probably the ESC. Good Luck
